I have a '94 306 xtdt. The car has just failed it's MOT for no light pattern on dip beam. It is fitted with 'Garrello' lights with two H1 bulbs.
I have checked the bulbs and they are seated correctly. I believe the problem is being caused by the plastic inserts inside the headlamps which focus the beam. The plastic has gone very 'green'.
I have took them out and scrubbed them with fairy liquid which has improved things but not good enough.
The question is can you buy new ones? Peugeot don't do them but does anyone else? Obviously I could source some new headlamps from a scrappy but are they going to be just as bad?
Another solution could be to fit a different make of headlamp ( with a H4 bulb. Do these fit my car? I'd have to alter the wiring but that wouldn't be too difficult.
Any help/advice appreciated.
Regards, Craig
306 Headlights
306 headlights
A bit late from the original post but have you found a solution to your dim headlights, how did you get the inserts out to clean them? I have the same prob on my 94 306.
Ian
This sounds like the Ford Mondeo mk 1 problem,where that has plastic inserts.The original bulbs would have been low UV bulbs,but as the years pass & bulbs are replaced,they are replaced with standard bulbs,where the UV discolours the insert.A lot of mk 1 Mondys fail the MOT for the same reason.
53`406 est SE Hdi 140,110k
hi on the subject of headlights, i'm wanting to update the look of my phase 1 306 by changing the headlights, just want to know if its possible to fit phase 2 lights onto a phase 1?
talking to a bloke at work he said because the only difference is the indicators are separate on phase 1, phase 2 lights should fit with little if any, bodywork needed.
does anyone know if this is true, or is it better just going for a pair of angel eye headlights off ebay?
cheers Ali
cheers Ali
Alas it's not that easy. Later headlights are more curved and won't fit your wings or bonnet and I believe the mounts are in difference places so you'd need a new front panel. All in all it's not worth it; stick with the originals as they already look great, especially if you've got front fogs. A very stylish nose, IMO 8)
Alex
2000 306 HDI GLX: http://oh.is.it/Pic/ViewAlbum.php?id=26
1994 306 XTdt: http://oh.is.it/Pic/ViewAlbum.php?id=25 (now sold )
