The sunroof cables are about £70 from Peugeot, and rust up through lack of use and water ingress. Take the sunroof glass off 4 screws on the front rail, and 3 screws on either side. Without the weight of the glass you maybe able to get the cables move. Believe or or not the Haynes manual (the earlier purple colour cover edition) cover's the subject in detail. I've done the job three times now, and now take me about an hour if its there are no snags.
Paul.
1st peugeot purchase !!
As long as you can see the roof working in the scrappy. It may be easier to change the whole sunroof assembly from another car. If you put new cables in i'd be inclined to take the roof assembly out of the car and clean where the channels where go and grease them before fitting the cables.
Series 2 405 sunroofs are different and I don't know if they are interchangable with the series 1
Paul.
Paul.
