I have fitted a Weber 38DAS to my 205xs. On full throttle it absolutely flies, but on part throttle there is a horrid flatspot and hesitancy.
I have replaced just about everything on the carb, to no avail. Some people are starting to tell me that the carb is simply too big for the engine and that will result in the flatspot.
Has anyone else heard of this?
Can a carb be too big for a car?
- My Cars: C5 X7 2.7 hdi
Past cars
Activa, silver MK1 (221bhp stock) stripped out with twin sparcos Evo seats. 95
Activa, light met red MK1 98
Activa, dark met red MK1 98
Activa, dark met blue MK1 (202bhp stock) 96
Xantia exclusive V6 auto 3l 98
Xantia 2l 8v auto
BX 4x4 GTi dark met silver
BX 4x4 GTi white
BX GTi 16v white fibre bumpers
BX GTi 16v black fibre bumpers
BX GTi 16v hurricane (doa)
BX DTR estate
- fastandfurryous
- Location: On the road, travelling at high speed. Meep Meep.
- x 4
Thanks for the response. As soon as I fitted the carb, I had it set up on a rolling road and the main jets were made smaller, but operator claimed the air correctors were OK, ie the mixture was good.
I have tried smaller idle jets and smaller accelerator pump jets and there was a slight improvement, but no real solution.
Will the flat spot be caused by the mixture being too weak or too rich? I looked at the plugs and they were black so I assume it is the latter.
The fuel consumption isn't too bad ie about 30mpg driven very hard.
- fastandfurryous
- x 4
Black sooty plugs is definitely rich mixture. Plugs should have a light grey/brown coating on them if the mixture is correct. I would be inclined to try tweaking the mixture with the correction screw (I'm fairly sure just about all carburettors have them) to make it slightly more lean.
Another way to tell is to have someone follow you while the engine is on it's flat spot. If there is visible soot from the exhaust then it is indeed very over-rich.
Good tip, but I doubt you would be able to tell the sooty smoke from the blue oil smoke!
To reduce the flat spot, I have tuned the mixture to be spot on, any deviation from that and it runs very roughly.
Thing is, the carb responds exactly as Weber suggest, ie the best running is exactly at the mixture settings suggested.
Past cars
Xantia 2l 8v auto
BX 4x4 GTi white
BX DTR estate
Contact cybernck on ActivaNet i know he does a lot with the XS and he is an admin on www.205gtidrivers.com and www.activanet.co.uk he is a top bloke we have been friends for years.
Andy
Andy
- fastandfurryous
- x 4
Looking at the size of carburettors fitted to different sizes of engines, and having just realised that we're talking about a 1360cc engine here, then yes, I get the feeling that this carb is just way too large for the engine.
How well does it idle? Lumpy? the airflow at part throttle through the venturi can't be anywhere near fast enough to create much of a depression!
I had a 1.9 engine in my mind for some reason, and was thinking that the carb was probably large for it, but would be OK... for a 1.4 it is massive!! You should be looking at about 26-30mm venturi's, not 38!
It idles quite well actually. Much better than the stock 32/34 SOlex ever did.
It also picks up very well, it is just after the initial pick up that the flat spot occurs. If I keep it nailed and get above about 3000rpm, when the power circuit kicks in, I guess, it really flies.
Because of the extra performance I am loath to swap it back to standard, but would like to try and eliminate the hesitation. So, if indeed it is too large, is there anything I can do to compensate for that?
Someone has suggested a progressive Nos kit to overcome the flat spot, but that might be going too far!!
