My mate reckons that an L Reg 1.6 Peugeot 306 is actually quicker than an N Reg 1.8XT Peugeot 306 - Is this true?
I cannot see how it possibly can be (unmodified) - it's not as if the weight would be any different.
Any ideas?
Is there a website I can look up?
Cheers
Peugeot 306 - 1.6 vs 1.8
- born2die
- Contact:
try https://www.theaa.com/portal/appmanager ... rch1/begin find the car you want and follow the prompts that should tell you ie this is for a 1997 p plate 1.8xs
Emissions and Fuel Consumption Dimensions
MPG NA Length mm NA
Tank capacity litres 60 Width mm NA
Litres/100km NA Height mm NA
Noise level dB(A)(moving) Wheelbase mm NA
Euro standard NA Kerb weight kg 1090
Particles g/km NA
HC & NOx g/km NA
CO2 g/km NA
Performance Engine and Transmission
0-60 time s 13.5 Engine cc 1587
Bhp 90 Drive Front Wheel Drive
Maximum speed mph 111 Gears 5 Speed
Maximum torque N.m 135 Transmission MANUAL
Maximum torque lb.ft 99.57 Fuel aspiration Normally Aspirated
Maximum torque at rpm 3000 Fuel catalyst Catalyst
Fuel delivery Multi-Point Injection
MPG NA Length mm NA
Particles g/km NA
HC & NOx g/km NA
CO2 g/km NA
<b>1.6 8v</b>
Engine Size: 1587 cc
Cylinders: 4
0-60 mph: 13.1 s
Power Output: 90 bhp
Valves: 8
Torque: 137 Nm
Torque: 101 lb/ft
Top Speed: 111 mph
MPG: 38
<b>1.8 16v</b>
Engine Size: 1761 cc
Cylinders: 4
0-60 mph: 11.1 secs (auto 14.6 secs)
Power Output: 112 bhp
Valves: 16
Torque: 155 Nm
Top Speed: 119 mph (auto 109)
MPG: 34
So it isn't on paper, although I'm sure my 1.6 is quicker than 13 seconds! (but I haven't timed)
But there isn't so much difference I don't think to justify the lower mpg of the 1.8
There was also a 1.6 16v very late in the life of the 306 which does match up!...
<b>1.6 16v</b>
Cylinders: 4
0-60 mph: 11.3 s
Power Output: 100 bhp
Valves: 8
Torque: 138 Nm
Torque: 103 lb/ft
Top Speed: 114 mph
MPG: 41
Cylinders: 4
0-60 mph: 13.1 s
Valves: 8
Torque: 137 Nm
Torque: 101 lb/ft
Top Speed: 111 mph
MPG: 38
<b>1.8 16v</b>
Cylinders: 4
Valves: 16
Torque: 155 Nm
MPG: 34
<b>1.6 16v</b>
Cylinders: 4
0-60 mph: 11.3 s
Valves: 8
Torque: 138 Nm
Torque: 103 lb/ft
Top Speed: 114 mph
MPG: 41
