heres how it all started.
I put in a boost gauge in to my 95 306 DTurbo today but to bring the pipe into the car my freind took the drivers door off, so he could feed through some hole. When it came to putting the door back on, the wire connector (sorry dont know whats its called) would not connect to the socket on the door so he straightend the pins with a screwdriver, but as soon as he touched a pin the central locking locked and then unlocked.
so now when activating the the central locking with the remote fob, all the doors work with the expection of the drivers side door. For example if the car is locked and I open the car remotely, the driver side door will remain locked. It will however open if the lock is turned manually, and also the passenger side window does not open. I have checked all the fuses but they seem to be ok.
Any suggestions would be great.
306 Central locking problem, plz help
