307 HDI now speaking french!
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
After sorting out the black death from the two centre injectors, and the air leaks from the leakoff pipes, I disconnected the battery for an hour, after a short session with the priming bulb it started well, and drives properly, a short ten minute stop and no start again, squeezing the primer did nothing, the display language is now in French! and it mentions "Antivol" moving the key away from the car and then presenting it again and she runs so I suspect the immobiliser is playing up, can anyone shed any light ?
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5648
Re: 307 HDI now speaking french!
PP2000 / Diagbox - really is needed to ascertain what is going, but have you replaced any parts recently with second hand ones - especially the head unit or screen? You very likely have a parameter configuration issue at the least.
- My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl - x 984
Mine always used to go native after the battery was off. Think you just press the menu button in the radio then down button till you see the languages. Get it back in English, them see what it's upset about.
- x 31
Right! its speaking English again, its telling me that the antitheft is faulty, nothing has been replaced apart from injector seals and leakoff pipes, anyone have experience of this, I will see if theres another key.
- x 31
Cleaned the key, tried the spare one, now they both work ! thanks to all contributors.
