Is there anyway to check the correct spheres are fitted?
Its a 2.0 8v 94 SX, and spring suspentions feel better and smoother then on this car. It was hydraflushed, new LHM, new spheres, and it still does not have this floaty feel i here people speak of.
I have to the pushing down on each corner and the suspention pumps me back up after a few seconds, so as far as i know they are not flat (we changed a few months ago). I bought them of GSF so they should be correct is there anyway i can double check it has the correct ones on?
Checking for correct spheres
Have you looked at the downloads section of the main site? You will find thet jon has posted a sphere application table there with serial nos etc.
having had similar experiences with my BS I suggest you look for other causes. Stiff front struts are the obvious cause - new ones made a world of difference to mine. The other thing that can cause rough riding is a sticky height corrector which doesn't allow the car to rise to its correct height. You can try raising the car and dropping it and se if the ride improves for a while and if it does try greasing the linkage, particularily where it goes into the corrector.
There are a number of discussions on lubricating struts - try a search.
Jeremy
Jeremy
