Clonk and Knocking
- New User
- My Cars: This is a dummy account added to fix some orphan posts.
Clonk and Knocking
Hi everyone. The cars going well except for the front suspension. If I am on full lock either way, when I start to turn the wheel back while the car is stopped or movind very slowly It makes a Clonk type sound. Also driving along bumpy roads the front suspension knocks. Could they be linked and what is the possible cause of both problems any ideas much appreciated.
itll be your drop links mine done the same cost £12.50 per side and 10 mins to change them its a different car to drive now fells much tighter.
dont bother trying to unscrew nuts cut them off as you get new ones with the links and make sure you get the right ones as i think theres 3 types just have a good look at yours ie which way the nuts are
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Alec</i>
I have looked on the gsf site and they only go up to 1998. Will I have to get the droplinks direct from Citroen? Or would it be worth popping into my local gsf first?
They are on the web site
N42265 ANTI ROLL BAR DROP LINK XANTIA 98> £10.00
I've just replaced mine from GSF
- New User
Mornlng. I did the droplinks yesterday and what a diffrence it has made the full lock clonk has gone and most of the bump knock, it also feels like I'm more in control of the steering. I still have some knock though so would I be best off changing both bottom ball joint or just the one I think it is (N/S). Once again thanks for everyone's advice.
