Xantia 2.1 td rough starting..update
Thought I was doing well , I've had the above for 6 months and other than a leaking tailgate all has been well.However over the last week the car has developed a problem when starting from cold , It fires up as normal after a couple of turns but then seems to miss fire which is accompanied with quite a bit of blue smoke.Once the engine has been ticking over for a couple of mins or driven about 500yds the problem vanishes and it runs as normal , it only seems to happen when the engine is cold...first thing on a morning or when leaving work.It's a 98 2.1 td with all the electronic bits ,has done 110k and has been serviced every 6k from new, the K light is not showing when the fault occurs ,Any advice will be greatly appreciated before I start looking for the needle in a haystack[?]
Your glow plugs need changing.
Get yourself a really good set of glowplugs (dont skimp on price).
When you turn your ignition on, the glowplugs light up and generate heat to normal running temp inside the cylinder and the the warnig light goes out on the dash to say you can start up. The glowplugs stay on after the light goes out and still glow when the engine is started, this helps the get the car running properly.
If one or more plugs have burned out you will get poor starting and rough running for a few hundred yards, and you will get blue smoke because the engine is not burning the fuel.
If you dont get the plugs changed soon, you will be replacing the battery too as it has to do extra work getting the car started in th first place.
Paul
PS dont get plugs from Halfords, they are C**p.[:I]
Paul
The glow plugs are bosch ones , do you think they should fail after 11 months ?.I'm not sure , as the car fires up fine(never turns over more than twice) and ticks over normaly for about 10 seconds before it starts to cough and splutter.I've also tried leaving the key at the preheat position until I hear the relay click off and this makes no difference at all[?]
Your glowplugs will stay on for a while after the engine fires, primarily to reduce emissions. This is controlled by the timer unit, not the plug itself. If you fit the wrong plug (eg from a BX) which is not meant to stay on after the engine fires then they will burn out quickly.
If the engine starts properly in the first place then your plugs are not burnt out! The timer may not be staying on as intended but while this might cause some smoke I don't see why it should cause uneven running as the BX has no problems here.
I think it more likely that some air is getting in somewhere and is being drawn into the pump after the engine fires. I'd start by looking at all pipes and their clips and at the leakof pipes. At least this is cheap!
jeremy
jeremy
Yes - I'm inclined to think along the same lines - air leaks are the bane of diesel engines, and the 2.1 liter is no exception - I had lots of trouble with this on my Xm TD12 until I was advised to change all the rubber fuel hoses - and another thing - does the TD12 in the Xantia still have the fuel preheater mounted on the left hand end of the head? If so, bypass it! It's a very common cause of air leaks - the aluminium casting become porous and lets in air.
//NiSk
//NiSk
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by myheadhurts</i>
To rule out a small air leak, try pumping up the primer bulb until it's firm before attempting the first start of the day.
Thanks for all your advice , I'll try pumping the primer bulb in the morning and see if it makes a difference.If it has an air leak somewhere would it not cause the car to run rough all the time ? ,as it is it runs perfect after the first 500 yards and starts without missing as long as the engine is still slightly warm.
