From the exploded view, my guess would be: No.9 is the shim (Keep the old one for re use), and 14 is a locking tab.
Cheers
Rear Arm Bearings
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
........and like I said - I think number 14 is a shim. Here's an extract from the manual. "" Assemble the arm in the subframe. Insert a feeler gauge between the spacer tube and the subframe and measure the clearance. Select the correct shim. Remove the fulcrum bolt, number 13, insert the shim and knock the bolt carefully in position. Fit a new nut, tightening to 94lbs.""
