Anyone think the Headlights on the early xantia are the worst ever!? they are so so dim (hope this isnt just my car or i may have a problem!)even my 2cv lights are brighter and thats with yellow bulbs!
I found this especially annoying when driving abroad with light deflectors on?! Is there anyway to improve them?
One thing that is also confusing is when i put the sidelights on I dont get the sidelights indicator lamp inside i just get the one above it, main lights, and on turning the stalk further it stays the same. The lights do go from side to main though outside. just not very bright. Anyone had the same problem? Or is it just the age showing?
TIM
Worst Headlights?
- Contact:
The headlights on the early Xantia's, upto 1994 are well known for being bloody awful.
Theres 2 options, either get a pair of Xantia headlamps for the 1994 to 1998 models, or else install 100w bulbs in your existing ones with a suitable relay.
As far as I can recall the Xantia only has a green warning light for dip beam, and not one for sidelights, assume this is to not encourage people to drive on sidelights?
Not so sure about the problem you have here then.
Anyone?
Anyone?
I think the headlights were improved for 1995, my 1995 Xantia had quite reasonable lights, but with a very sharp cutoff, so some people thought they were no good.
My 1997 (mk1) Xantia has different headlights again, the lenses are a different pattern (less fluting in front of the dip beam reflector) They have a much less sharp cutoff, so light up signs much better.
My 1995 Xantia had a sidelight warning light, but the 1997 does not.
- Contact:
Yep,
I have a '96 Xantia which a noticed recently was a '94 build[:(!]
It's headlights are bloody terrible. I drive the BX or CX given a choice if it's dark. My CX has vastly supperior lights to the Xantias Highbeam .... and I'm talking the CX with it's headlights on lowbeam[:0]
I going to eventually as soon as I find time fit new high wattage globes and relays. I did this to the BX and it's headlights are brilliant (literally [:D])
seeya,
Shane L.
seeya,
Shane L.
I've done the retrofit of 100Watt globes and relays to my 1994 Xantia. A really worthwhile upgrade, even for those that cannot access 100Watt globes. I will email a circuit diagram for those that request it : nicolewis@optusnet.com.au
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Forth</i>
Dip on the ZX is none too hot.... was no big problem till (as a government plot against rabbits??) they stopped people from using properly-aimed and non dazzling fog lamps on country roads .... grizzle, grizzle, grrrrumph....
That surprises me, mine is excellent. Have you tried cleaning up the earth connections on the lights? It made a big difference to the amount of light put out. I've also changed the bulbs to GE Super Blues (which thankfully aren't blue !!!!), but cleaning the earths up made the biggest difference.
Yep got to say the lights on my old ZX td were a lot better than the first Xsara (98 reg) I had. The Xsara had new bulbs from Hal****s their own make, satisfactory is how I would put it. My new to me Xsara same year has great lighting. Again only a dash indicator for full beam, high beam front & rear fogs.
