diagnosing knackered xantia struts
the fast ticking is probably due to a worn non-return valve in the regulator itself. the good news is that you can re-seat this valve yourself at no cost. To do so, remove the accumulator sphere and then remove the 10?mm bolt and the plate. the ball bearing will now probably fall out in your face but must be found. to reseat somply tap it smartly into its seat using a BRASS rod (not steel - this will put a flat on the ball) and re-assemble. A dab of grease on the ball helps hold it in position.
Usual safety warnings apply of course. On my TD BX I can do this job with the regulator in the car.
With regard to the rest of your problems let me say that I have no Xantia experience at all. What I do know is that strut friction is very important and a small amount wrecks the ride. You should be able to push the car up and down at both ends and it should move easily if everything is ok. if it won't move at all then suspect spheres, if its very stiff or jerky suspect struts. Certainly on BX the back struts seem to go on for ever so try bouncing that end first and see if it moves smoothly. The front should be much the same but doesn't move as far.
other things worth looking at are subframe mounts, tyres and pressures.
jeremy
jeremy
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jeremy</i>
If you arenot careful you will find that your eye is the perfect collection tool! Ideally some form of tray helps.
jeremy
Ah, does the man speak from experience?
jeremy
