LHM
LHM
Hi all, question, My Xantia td is working fine, BUT,it is loosing LHM fluid and I don't know where too. No puddle on the floor, and no visible leaks around pipes or suspension parts. Looses about 1/2 L a month.I have had lots of experience on Citroen hydraulics but this has got me puzzled. Any ideas?
Regards
Paul.
Regards
Paul.
2 types of LHM drinkers :
1) disc brake pads, as they wear the caliper pistons moves out.
2) spheres running flat, as the gas disappears the cavity is replaced by LHM.
Before topping up again :
try set the car in low, then release the system pressure.
If the reservoir now seems overfilled, then you have a couple of weak spheres.
Only if the spheres are completely flat, no remaining pressure exists to press back the LHM to reservoir. Even the slightest (1-2 bar) pressure would press back the LHM.
This can only happen when suspension is set to lowest, as then the HC's are forced open between suspension cylinders/spheres - and the reservoir.
Update, LHM on top of reservior just leaking out from return pipe seal, no problem.
Replaced 4 spheres, accumalator sphere replaced 10 months ago.
Drained and cleaned the reservior,Drained the yellowy LHM and refilled with Hydroflush, bled the brakes. did Citaerobics.
Car now running fine (Touch wood), doesn't drop to the floor as quick, ticking about every 20 seconds, Feels a lot taughter too.
Will update.
Paul
Will update.
Paul
Seems the hydraflush have solved your problem. If you're still losing LHM/Hydraflush, it could be a leaking brake valve as it leaks inside the cabin, right under the brake pedal onto the drivers floor. The foam on the floor will soak up more than 1 liter of LHM, mine did. The leaked LHM will eventually drip out through the floor as something like thick grease. Lift up your carpet to see if the foam is wet with oil. If it is, try soaking up the LHM with newspapers and cloth.
