Air Con again
Our most popular forum is for Citroën problems, discussions and chat.
Specialising in AX, BX, ZX, Xantia,C5, Xsara, Saxo and XM. CX, 2cv & Berlingo, all are welcome.NOT for selling cars/parts!
Robbie
My Cars:
Air Con again
Postby Robbie » 18 Jun 2002, 22:02
Well phoned Citroen and asked how much to check and regass my Xantia, £90 plus VAT but it will probably be leaking so may need more doing and we can't look at it for about four days. Phoned a little place round the corner that does trailer fridges, they said free check, and £50 to regass,and bring it straight round, went to see them, they put a digital thermometer in the car and turned the Air Con on it said 15 degrees and that was after I had been driving for a while, they checked for leaks and said it was low, but no leaks, probably just natural leakage, they topped the gas back up again, the thermometer dropped its reading to 5 degrees and now its absolutely wonderful, “how much do I owe you” I said. “£30” he said, I will be recommending everyone I know to use this place.
A nice cool Robbie.
0 x
JohnD
Donor 2016
My Cars:
Postby JohnD » 19 Jun 2002, 02:07
So where is it?
0 x
Robbie
My Cars:
Postby Robbie » 19 Jun 2002, 03:51
It's called ColdStart and it's on little Tennis Street in Nottingham.
Robbie
0 x
alan s
RIP 2010
My Cars:
x 4
Postby alan s » 19 Jun 2002, 18:56
Robbie,
Far be it for me to rock the boat but as a qualified refrigeration mechanic with many years of experience, I can assure you that there is no such thing as "natural leakage" in a refrigeration system; it just does not work that way. If the system is low on gas then it was either low when it left the factory or the last time it was serviced, they didn't fully charge it. Refrigeration/air conditioning systems are a sealed system and unlike a gas stove, they don't consume gas they actually circulate it in their systems.
I won't comment on price as we live a half a world apart, but I will tell you that if the system again gets low on gas, then it definitely has a leak which must be repaired. In most cases this leak usually turns out to be on the TX valve which is normally found on the intake to the evaporator & can be accessed on some Cits by removing the glovebox. All car air/con systems should be run at least once a month to prevent the low pressure side of the system building up back pressure & allowing a small low side leak to create problems that would be greater if left idle.
Alan S
Edited by - alans on 19 Jun 2002 14:00:06
0 x
David Goddard
My Cars:
Postby David Goddard » 20 Jun 2002, 03:36
Whilst the refrigerant "leak" rate is virtually zero on a say a fridge or freezer, flexible hoses are needed on cars between engine mounted compressor and the rest of the a/c system. Rubber is permeable. So, in the same way as tyre pressures gradually decreases due to diffusion through the rubber, the same tends to happen through the a/c hoses.
The rate of diffusion is dependent of the molecule size. Freon and the more recent alternatives have relativly large molecules so, despite the higher operating pressures vs tyres, it could be 5 years or more before the effects of reduced refrigerant levels become noticable.
0 x
mazidee
My Cars:
Postby mazidee » 24 Jun 2002, 12:16
My mechanic said that my ZX 1.8 aircond gas is rather low as it did not activate the radiator cooling fan fast enough. I complaint on the slight temprature increase than normal. What is the correct gas preasure for Citroen ?
Mazidee
Malaysia
0 x
Return to “Citroën”
Who is online
Users browsing this forum: No registered users and 9 guests
