BX Turbo Roto diesel pump seal
The oil seal on the shaft to cam wheel appears to be leaking diesel.[}:)][}:)]
Does anyone know if it's available as a spare part?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tomsheppard</i>
Tee Hee- Sunshine!
And I bet I know where the sunshine is shining from[}:)][}:)]
Tee Hee- Sunshine!
Hi Bernie,
If it's any help I have changed the shaft oil seal twice on the Lucas pump on the Visa Diesel.
Seal was available seperately from a Lucas outlet in Cambridge.
Rust builds up on the exposed part of the shaft, so this needs to be carefully removed with fine wet and dry soaked in diesel. If I remember it was quite tight to get into the recess.
Do not lubricate the outer circumferance of the new seal, only the shaft.
Good luck.
Good luck.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by oilyspanner</i>
The bosch pump is better, why not fit it anyway?
Stewart
In what way better Stewart?
Stewart
Allegedly better quality, reliability,Tuning etc the Bosch is generally the preferred option, given the job you must do theres really nothing in it, if you look at the ally casting that the pump sits on you will see that there are two sets of stud holes, merely swap the studs into the other set of holed and pop the Bosch unit on, you may have to faff around with the timing a bit, as you have the bosch pump anyway why not?
Stewart
Stewart
Don't swap the pumps - repair the original and preferably get a Lucas diesel specialist to check the drive end bush clearance in the pump - this is replaceable.
Pumps are set and calibrated for each individual engine application - in view of my "handle" I won't be drawn into the respective virtues of Lucas and Bosch pumps. Suffice to say that either will outlast an engine if properly treated - clean fuel and correct cambelt tension.
rotodiesel
rotodiesel
Hi again Bernie,
Absolutely no axe to gring on either pump manufacturer, but I must add the the front bearing on the Lucas pump started to break up and the pump was acelerating on it's own, scarey,(I must take that one apart completely, just out of curiosity), so I obtained the other make complete with injectors from a breakers...
Cheers
Cheers
