xm clutch cable
Our most popular forum is for Citroën problems, discussions and chat.
Specialising in AX, BX, ZX, Xantia,C5, Xsara, Saxo and XM. CX, 2cv & Berlingo, all are welcome.NOT for selling cars/parts!
jimbo
My Cars:
xm clutch cable
Postby jimbo » 10 Jun 2002, 16:36
How difficult is it to change the cable on a 91 xm 2.0 si petrol
and can andyspares supply the cable.
0 x
Zummerman
My Cars:
Postby Zummerman » 10 Jun 2002, 20:54
Hi Jimbo,
Fiddly, but not difficult. The Haynes manual gave me almost enough clues. I assume that your cable is the self-adjusting type. If so you'll need to use something appropriate to jam the cable outer in position in the frame that holds the bellcrank (where it comes out of the bulkhead) so that you can extend the cable to locate it in the lever at the bellhousing end. I think I used a square screwdriver between the cable outer and cable end. Small hands and a little imagination are helpful in fitting the cable to the pedal...
Good luck!
0 x
Return to “Citroën”
Who is online
Users browsing this forum: KennyW and 16 guests
