Citroen XSARA SXTD 1998 Problem with the Fans.
Please help me.
I Have A WEIRD Problem.
Before the problem started, this is the Data:
90C on hot day, without A/C
75C On hot day, With A/C
Today, its
90C on hot day without A/C
95C on hot day with A/C
i dont know english very well, but i can tell that the Fans are not working as they used to, its not Getting in to 12V Mode.
only 9V works.
But, sometimes if you press hard on the gas pedel, or turning on/off the car, they Get intoaction at 12V Speed.
But quickly shutting down.
I Suspect(from what im reading here) This is the bitron unit. The engine is DHY Turbo Diesel Engine.
Where can i find this Bitron on xsara TD?
and if it does use bitron, what his color, or how can i Bypass it.
thank you.
Today, its
only 9V works.
thank you.
- My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2 - x 1
Its just tired French electrics, The terminals get dirty & the gaps in between the terminals in the socket part of the connector gets bigger & you end up with strange electrical faults.
Im not sure if the Xsara has these fitted, but the big round connectors behind the left hand headlamp that Peugeot & Citroen used on some cars are really a load of rubbish when they get older & the cause of a lot of electrical faults too.
Past:
Hi
Its the brown plug that sends the Bitron unit the information to run the fans.
You might need to fit a new temperature sensor to the car.
Have a look at this link, It has the circuit diagram for the Pug 306 with aircon & twin fans.
Click on Electrical at the top, & then click on 306 cooling fans basic principles of operation in the list on the left hand side.
http://www.peugeotlogic.com/workshop/base/workshop.htm
Peugeot & Citroen are the same company, So the circuit should match up with whats fitted to your Xsara
