a green 19 td spares/repair
L reg no tax/mot
needs a screen and head gasket
still runs fine has done 3500 miles with this problem a water leak at head/block joint under the diesel pump.
comes with a headset and bolts and timing belt just need to get right head gasket (notches) also comes with a unfitted new heater maxtrix .
had a new battery in january
also new wheelbearing to o/s/f and the drive flange.
a new accumalator sphere, flushed the fluid and replaced and new rear height corrector.
had enough of waveing spanners at it. i have 2 other cars so this one can go !!!!!!
oh screen is £90 + vat but they reckon trim breaks and cost an extra £57 quid so i have got a spare unbroken one in boot (got at a scappy for £5)which i removed myself so i'm sure i can remove the one that is fitted no problems if not they can use the spare one .(auto gla** you robbers!!)
make me a sensible offer on car as is or a very high offer and i'll repair it!
xantia 1.9 td 1993 spares/repair
- ukmobileman
- Contact:
