Sometimes when i open my tailgate,the handle sticks.So when i shut it,it doesn`t allways lock.You can still open it without using the handle.By using the handle or locking & unlocking a few times it sorts it self out.
Anyone any ideas?WD40 somewhere maybe?
I never use any door locks,allways the remote.Although a few times i use the locks to make sure there still working.
Thanks..........
Xantia boot lock
Take the trim panel off (lots of plastic torx screws) And you can get to all the moving bits of the lock, If it sticks when you push it in like mine did its just a case of wiping the dirt off while holding the button in and giving everything a spray with WD40, freed everything up nicely, and a lot more positive click now!!
Spraying around the button from outside, with it pushed in would have worked just as well I think[:D]
