What wheels fit to citroen cx turbo according to original specification?(not TRX). I have 205R15 wheels i don't know what tires to buy. If i only to know original size, i will convert them to the size i need.
Cx wheels and tires
- Contact:
If it's a CX2500 GTi Turbo, with the 'T' wheels, they are DEFINATLY TRX tires (you poor bugger). The tires themselves are 390mm, so ONLY metrix TRX tires can fit. The correct size is 210 390mm. Apparantly only 220 390mm as available, but you better sit down before you get quoted on a set of these. Michelin and Avon produce TRX tires.
A much better option is to fit aftermarket wheels as tires are then a fraction of the price. Eg: for my CX the TRX tires we to cost about $550aud EACH (if I could find them). Now, for $200bux a peice I purchased new aftermarket wheels, and $120bux each bought brand new Simex performance tires to fit under it.
You'll have to put some effort into sourcing wheels that don't touch, note the rear spats aren't fitted to my car as they tires **just** touch them ...
good luck
Shane L.
good luck
Shane L.
