zx wont start after running
anyone please... my zx 1.4i goes well untill you stop it, if you start it imediately it may go but after a few minutes it just wont start. eg going to get some fuel. i had it tested by garage and they said it needed a new single point but after fitting a gauranteed second hand one it's still the same. strangely after removing a wire/plug connected near the top of the injeactor it might go...
- uhn113x
- My Cars: 1981 Dyane - on road all year round.
1982 GSA Pallas - on road April - September.
1997 ZX 1.9D Dimension. - x 1
Hi Borriss
You need to catch it in the act, and find out if it is a fuel or ignition problem, otherwise you will just be on the hiding-to-nothing 'diagnosis by guesswork' method - time consuming, expensive and will introduce more faults.
Is there anything (fuel) coming out of the single-point injector? Is there any spark?
Various things can fail when warm.
- uhn113x
Hi Borriss
Ther is no choke on an injection system. Enrichment when cold is done by the ECU lengthening the injection period by sensing coolant temp from a sensor somewhere.
I would do a general check on wiring, connectors, hoses, etc. first.
On my DS there is also a 'cold start injector' that gives an extra squirt when you operate the starter, but I don't think any SP injection systems have such.
Normally the only sensor you find in radiators is one for an electric fan which is usually near the output. Putting one near the inlet would I suppose be a fair way of getting one to tell when the thermostat opens which could be useful for a fuel injection set up. Incidentally for example BX (and I think ZX) have a fan thermostat which is about 1 inch in diameter and certainly on twin fan cars this has 3 terminals.
Most temperature sensors for temperature gauges have a single connection. sensors in radiators probably have 2 as there is no reliable earth. gauges and warning light sensors are usually somewhere around the thermostat, and I think it unlikely any fuel injection sensors are off the engine itself.
I expect there is a diagnostic plug somewhere - might be worth getting the codes read. otherwise try and find a description, work out what sensors there should be, find them, check their wiring and for example if they are temperature sensitive try and test them with hot water. If you have things like throttle switches these can fail - gaain careful testing with a meter should reveal the problem - ie you are looking for smooth changes with no jerks in action.
jeremy
jeremy
ok this is getting tough, Garage i went to said it needed new injector body and stepper motor, now I'm not a mechanic but that sounds slightly excessive considering the car is fine except when starting from hot. does anyone know if this sounds right and of any good garages/citroen specialists around london, south or otherwise?
I suppose another cause could be fuel vaporisation? Engine hot - standing - heat soaks into components or pipework, fuel vaporises . . . As throttle body has been removed have all gaskets and heat shields been replaced? carburrettors often used to sit on 4mm or so of insulation with a gasket each side. Other possibilities are fuel pipes too near exhausts . .
Jeremy
Jeremy
- uhn113x
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">ok this is getting tough, Garage i went to said it needed new injector body and stepper motor, now I'm not a mechanic but that sounds slightly excessive considering the car is fine except when starting from hot. does anyone know if this sounds right <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Sadly, it does sound right for a garage. If you successively replace every part, charging the customer for your 'training' each time, chances are you will either cure the problem, or the customer will get fed up with spending money and go away.
Whatever happened to diagnosis?
Cynical, moi?
Cynical, moi?
