I hope there is some citroen gurus in here that can help me.
Basically my Zx is having problems when accelerating. It tends to hesitate if i put my foot down after a 1 -2 mins of driving, it becomes so bad that in the end it cuts out and then when I restart it it works ok again for about the same length of time.
I took it to a citroen dealer and they said the throttle body and water sensor needed changing so I did. Still no good exactly the same problem, I have also changed the ignition coil with still no joy.
Can anyone help???
Citroen ZX 1.4i K Reg juddering
That remark about "better from cold" seems to suggest that there may be some form of fuel problem. As when cold the cold start part of the engine enriches the petrol mix so giving an easier start. When hot this is backed off. As the car is hesitating you could have some form of the cold start being stuck on. What colour were your plugs when changed? if black and sooty this is a sure sign that you are running too rich.
