zx 1.9 d start problems
bad starting in the morning, new heater plugs, still the same should the hand primer get hard after two or three pumps, mine stays soft all the time, return pipes from injectors the small plastic ones, one is leaking slightly, fuel filter housing when i took the top of this the fuel was only approximatley 1 third up the pot is this correct.
