the sunroof on my 92' xm is not working. it makes a noise when the buttons are pressed so i assume the motor is still operative to some degree, but no movement of the glass.
Any suggestions is this a big & costly job?
bought my 92' xm 2 ltr for £435 with 12months mot, 6 months taxed, FCSH for first 4/5 years as company director owned,then owned by an engineer at the same company who serviced it himself, large history file, i am third owner. Spent £50 to get the central locking sorted, apart from that almost mint, interior mint & never smoked in.
Do you think i got a good deal, not too sure what going rate is for an xm.
also what should the stock wheel covers be like on this series?
thanks for any help.[8]
xm sunroof
You can get access to the motor by removing the interior light assembly. You wont be able to see much other than the motor and gear mechanism. If your fault lies elsewhere you will have to remove the plastic roof trim to get the sunroof out. Mine had a gear fault so I didnt need to do this.
The price you paid is quite reasonable.
The wheel trims are a plain disc with 5 silver discs in the centre. They are expensive - £55 each. I lost one and decided to replace them with a set out of Halfords which I think look better.
Hello!
As jack said about the motors location, i will give you my experiance on sunroofs!
It sounds like to me the cables are seized so they would need replacing which is easiest if you drop the headlining down to remove the complete sunroof assembly. But before that i would be inclined to remove the motor first and check the teeth on the drive. Then look inside the area where the motor drive was engaged into and you will see part of the 2 sunroof cables. Check carefully to see the condtion of them. (You can only see a small part anyway) If ok , then i would remove the glass which i think is held in with 4 Torx screws. Then you can careful push the sliders back a bit to see if the cable or cables are seized. Sometimes a bit of spray grease helps but if the sunroof has not been used for a while it may be well seized. Then you can decide on your next course of action!
Hope that helps!
Good luck.
Hope that helps!
Good luck.
Sounds silly but once repaired the electric window winder on an old Rover 600(argh) buy using the same wire / steel rope as uesed for bike brakes. Bought about 10ft from Ha****s and made a good repair. If you can get the wire out you may be able to get fresh stuff in for a fairly decent repair. Sorry cost was only a couple of quid.
Some members of the XM List have done it. Try www.yahoogroups.com and join the XM discussion group.
