Whilst effecting a temporary bumper repair on the ZX last night (see post in For Sale....) I noticed a bit of grease splashed around the inside of the wheel arch. Sure enough a look underneath shows the boot has started to leak. Not sure if it's split or the strap has come off the outboard end (was getting dark by this time).
So, if it needs to go back on will cable ties do? If not is it possible to do up the ligarex without the special tool? If I get a boot kit, does it come with new straps, and same question about doing it up?
Seems a bit common this, my Sister's ZX D keeps popping the near side boot off, and now mine has let go. Hmm.
Cheers [:D]
CV Boot straps / ZX hub nut size
Cable ties will do fine as long as you pull them up tight and cut the ends off short- I have never had any problem with them at all ones- on the other hand I have never had any success with the steel bands that normally come with kits!!
If one tie won't go all the way round, and the ones I swipe from work don't, you can just use two.
I would try the cable ties first. Make sure you get very long ties, - you want the tie to be very tight, and it is easier to get a good grip to tighten the tie if you have some extra length to work with. Ligarex is good, but you need to have some clearance area around the axle in order to use the tool properly.
'13 3008 1.6 HDi GripControl - x 1002
Thanks guys.
Cursory inspection this evening shows both ends of the boot still attached, so it must have a hole in it - didn't find it though as it's still wet and horrible here!
So, next question, what size is the hub nut? I hope Citroen have done something sensible for a change, and made it 35mm same as the Xantia[8)]
