When trying to replace my sisters clutch cable on her 1996 Saxo 1.4i VSX I managed to detach it from the pedal and also from gearbox end. The trouble then started because I could not get the end of the cable through the bulkhead because of two metal bars which allow no room for movement or removal. In the Haynes manual these are not mentioned. It is impossible to see where the cable goes through the bulkhead as these two bars cover the area. Has anybody changed a cable and managed to get round this problem?
ChrisK
Saxo 1.4i VSX Clutch Cable
