In the last few hundred miles I've noticed my zx 1.9d is making a clunking noise from the front end. Its no that loud and sounds a bit like the du-dum du-dum noise of a train. It happens when travelling below around 40mph, straight and cornering. Not sure if it stops above this speed, or is drowned out in road noise. I've done circles around an empty asda carpark but hear nothing, taking suspicion away from the cv joints. Ive had a good look at both front wheels bearings, and all seems fine. The gaitors are good and I can't find any play in the driveshafts. The only thing I can notice is the passager side drive shaft, which seems of larger diameter that the drivers side, has a little axial play. It can be pushed slightly towards the engine, and then springs back. Is it supposed to do this, or could this be the problem?
It feels like positive movement, and is only in the direction parallel to the shaft, almost as if it is suppose to do this, but then this movement is not in the drivers side. Any suggestions?
zx clunking
'13 3008 1.6 HDi GripControl - x 984
Jim,
A few mm of axial play is normal in the shaft.
Is the noise regular and speed related (eg something that is going round) or related to road surface? If the former, then wheel bearings, CV Joints, RH shaft intermediate bearing have got to be candidates, as are a brake pad catching or something. If the latter, then drop links, bottom ball joint and wishbone bushes are the candidates.
You may have to wait till it develops a bit more before you can nail it down!
I agree with UHN113x. My old ZX td had this rumble, clonk sound and I couldn't find at all. A couple of garages had a look and found nothing. I bit the bullet and fitted a new drive shaft (second hand), bottom ball joint but I also had a look at the drop links. On the car they seem OK but once removed, they were rite sh**y. No grease and loads of play. Any how managed to get some grease in to them and re-fitted. All was OK after and still is according to the garage I sold it to as a part EX. Funny really I thought they would sell it on or auction it but no they have kept it as a run about for the staff on sales pitch sort of fetching and carring.
Many thanks for your replies, I'm back home from uni now, so access to more space, and more tools! Still have the clunking noise, but its not continuous only occasionally. The only thing i have found is that if you grab the front passenger side wheel at the top and shake it vigorously there is a slight knocking movement. However when I jack the car up and repeat this shaking, no movement, and so don't suspect the wheel bearing. When you lower the car down again and shake once more the knocking has gone. If you roll the car forward, and repeat shaking, it will then knock again. I assume this is because as the car is lowered the wheel is at a slight angle and so forces are pushing against the worn part, holding it from knocking. Any ideas as to which part this could mean is worn?
By drop link do you mean the vertical linkage that makes up part of the anti-roll bar? This looks shiney and new, as if it was recently renewed (I only got the car a few months ago).
I will investigate further as and when I get the chance (I live on a farm), any more suggestions on techniques for investgating the various parts that could be to blame?
