O/S Headlight
- New User
- My Cars: This is a dummy account added to fix some orphan posts.
O/S Headlight
A simple one I hope. How do I replace the bulb's in the drivers side headlight. Xantia HDi 2000 W.
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
If the 2000 model is the same as the 1998, it's a bit of a squeeze to get behind the headlamp. There's a cover to remove first. Press down the clip that holds it. Remove the wire connector from the rear of the bulb that's to be changed. Outside bulb is dipped, inner one is main beam. Undo the retaining clip and remove the bulb.
