Hi I have just checked the oil on my ZX and have noticed water collecting in the low part of the sill (near-side) that runs beneath the windscreen. There's a plastic "leaf?" cowl restricting access to it. On the off-side it is empty and clean. Is there a drain hole or tube that drains this water away?
Ta
Water Collecting in n/s sill over wheel arch -ZX
The drain is actually where the wiring loom passes through the scuttle. It always gets blocked. You can carefully poke around the black foam around the loom to enlarge the hole. Some choose to completely remove the black foam grommet around the loom allowing a 2" drain hole. The loom sits safely in the large hole, nothing to rub against. Water drains instantly.
