Hi i'm new to the site but can anyone help.Ihave a xantia 19td and terrible starting in the early morning but yesterday afternoon was not too bad it starts and runs ok when warm any suggestions.
Cheers AJ.
Starting problems
The xantia has several well known issues but the best place to start is to check the glow plugs. Test lamp between top of plugs and engine block, turn ignition on lights up?
Yes, good.
Remove wire from each plug. Test lamp from wire to top of plug. Ignition on Lights up?
Yes, good.
That's the first test. Duff plugs can be replaced for a fiver but the one behind the fuel pump is a little tricky!
Yes, good.
Yes, good.
- My Cars: BX TZD @ 250K miles (J reg),
Xantia TD @ 165K miles (R reg),
Xantia 2.1 TD (R reg)
and tow a caravan with them all (not at the same time)
With a bit of luck, it'll be the glow plugs. If it isn't you'll find many a reference within this forum to Xantia TD's with 'poor starting'. These particular cars start on the button when warm, and run smoothly whilst driving, but are absolute pigs to start when the weather's cold and they've been stood for more than a few hours. I for one have tried most of the suggested fixes within these pages - but usually 'run out of steam' and motivation by the time the weathers improving and the problem goes away. I can tell by the service history supplied with my Xantia (which has done 140K miles now) that the problem must have been first reported at about 30-40K miles as this is when the first set of glow plugs were changed - the obvious reason for poor cold starting. It becomes clear when looking at the number of plugs fitted by the service agents over the years that this was not really the problem. Roll on summer..!
