Xantia cabin air filter
Does anyone know how long it should take to replace a Xantia cabin air filter? I started doing it and looked like half the dash was going to have to come out...does this sound right?
it takes less than 2 minutes to change the pollen filter ( im assuming thats what you are talking about).remove the screws holding on the carpet trim under the glovebox & there is a small plastic panel you remove,its either held in by 3 screws or slides to the side then it pulls down,pull the old one out & fit the new one.
