Can anyone help me locate the wires which are supposed to go to the front discs to operate the pad warning light.
All the wires are missing off both sides but cant seem to locate where they were supposed to plug into the main loom.
Have looked underneath the car to the rear inwards of the front wheels but there doesnt seem to be any spare plugs etc.
The reason I need to find these is because the pad wear light is permanantly on, and fear someone may have cut them off and maybe shorting on the body somewhere.
Your help will be appreciated,
Thank you
Paul [:)]
Brake pad wear light ( Xantia)
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
The connector is usually secured to the handbrake cable but where they go after that I don't know. I'm pretty certain they don't follow the handbrake cable.
There really shouldn't be any reason for anyone to cut them back beyond that connector on a car that age anyway.
I'm sure somebody will have a wheel off this weekend and take a look for you.
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
OK, I had a qick squint behind the wheel and I must have been thinking of the BX.
The plug seems to be to the front of the hub, not far from the ABS sensor, the wires disappear straight back along the line of the driveshaft. Looks to have thick insulation and sturdy clips.
Mines a facelifted '98 model.
Thank you for finding the time to have a look, on my Xantia there is no sign of the wires you have mentioned,have also looked underneath by the power steering rack etc and no sign of any spare plugs etc, will have to get the old inspection lamp out and spend a bit more time looking as this flickering light is drivin me nuts !
