Hello again,
I hooked up a spare boost gauge tonight... one advantage to modding cars is that I have a lot of spare equipment [8D]
I took the signal off the line that drops from the IC to the pump, ran the signal out from the bonnet through my window and went for a drive. Max boost I could get was 12 PSI although it builds quite quickly and holds 12 PSI through to redline. I thought factory boost was 1 Bar or 14.7 PSI? Obviously there's some room for adjustment here so how far can I go assuming I address fuelling? It's only a small turbo so I'm thinking much above 18psi is going to be going way above the efficiency range of the turbo. At what pressure does the inlet charge become above 'recommended' temps?
I had a look under the car and was quite impressed with the technology. My ZX has the KKK turbo with an external wastegate. I'm used to Garrett turbos with the integral 'gate - my Mazda has a T28 turbo and electronic boost control. The KKK looks like it's going to be a pig to adjust, access seems pretty limited. Any 'gotchas' with my plans or should I just leave it alone?
Thanks,
Phil.
Volcane TDI... Only 12 PSI!
http://homepage.ntlworld.com/ken.waters1/306_tuning.htm is the link you're on about, reffro...I keep it as a favourite!
I've got an old pressure meter I want to install to my Xantia 1.9TD. I've bought 2 meters of reinforced clear tube to join from the engine bay to the cabin but where should the tube go through the firewall? Anyone have done this before? The tube is about 1cm in diameter. Which is the best place to thread it through to the cabin?
