Sump gasket?
Sump gasket?
Not wanting to hijack d4mop's thread on oil leaks, what's the life of the sump gasket like on the 1.9TD lump? I ask because there was a light coating around the gasket when I changed the oil this weekend and there have been a few spots appearing on the driveway over the last few months, but I'd put that down to my crappy old sump plug.
Is it possible it's leaking from the gasket? Thinking about it, my engine looked like it had some rubbery sealant rather than a gasket. Is this normal?
Are there any weak points in the XUD that are known to be the source of oil leaks?
Just been out and had a poke around under the bonnet, and now I'm questionning my own diagnosis. True, the oil is collecting around the sump gasket, but there's oil further up the engine. The front of the block between the head and sump are pretty filthy, a combination of oil and road dirt, and there's small pools of oil on the head, around the injectors.
It's quite baffling. I don't think the head gasket can be leaking as I'm having no other HG-related problems such as mucky coolant or air bubbles, though that does seem to be the point at which the oily block starts. Mind you, how would oil get up to the injectors from there?
If it were the rocker cover gasket, surely there'd be more oil around the injectors?
It's definitely coming from the front though, as the sides and rear of the sump are (comparatively) clean, though the gearbox side is a bit grubbier. I think this leak is slowly getting worse, haylp!
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by batwad</i>
I'm surprised by this. Having had five XUDs over the past thirteen years, I've never, ever needed to change a sump gasket. Good luck, or what?
Right, with the bank holiday weekend approaching I think I'll prepare to find this bloody leak and (hopefully) stop it I'm just wondering that if I've got sealant stuff instead of a gasket at the moment, is it alright to scrape off the old sealant and replace it with a gasket or do I have to use sealant? What sort of sealant should be used?
What appeared to be a sump gasket failure on mine was actually a rocker cover gasket. The oil was running down the back (and front) of the block to the crankshaft oil seal area.
When my head gasket failed, small amounts of oil and gas bubbled out from under the joint by the injectors.
Oil leaks: having run a Triumph 650 Bonneville in the mid-seventies, I would observe that the time to worry is when the engine stops leaking. It means that all the oil has gone...
Take it as a "visual dynamic oil presence indicator system".
rg
rg
Ah, British Bikes, I too have been there with the primary chain case, sheet of glass, and grinding paste.........
Back to current oil leaks,when my BX diesel got more and more oily, most of it turned out to be coming from a split in one of the breather pipes where the pipe had perished near its join with the rocker cover.
