Since changing the oil when I first bought the car, about ounce a month the oil level light flashes for about twenty seconds when I turn the ignition on.
I use fully synthetic and it uses no oil, and the car is usually hot when this happens, If I turn the ignition off it goes out and doesn't come back on.
there doesn't seem to be any pattern to it............ANY IDEAS ANYONE.
FLASHING OIL LEVEL LIGHT
I found this with my Xantia, fully synthetic oil makes it flash a lot, with semi-synthetic it does it occasionally, with mineral oil it never flashes. Its very common with Xantias, being parked on unlevel ground, and/or re-starting with a hot engine seems to make it happen more too.
I don't think there is any cure as such, and its not really a good enough reason to stop using synthetic oil if the engine runs fine on it.
You'll probably just have to learn to live with it, its not really a 'fault' as such.
Nick
Nick
