Xantia height
Xantia height
What is normal height (distance from the road) for citroen xantia (front and rear)when lever is set to normal? Where is it measured?
Correct height is exactly on the midpoint betwen lowest and highest position. On Xantia MkII this should be about 67.5 cm front, 62.5 cm rear, from the ground to the wheelarch, with 185/65 R15 tyres. Mine is a bit lower (66.3 cm front, 61.5 cm rear), I'll adjust it in the future, but there's no big difference.
