Are these identical to the TZD calipers? Or are they more hassle than they're worth?
I've tracked down a guy about 15 miles from me breaking one.[:)]
BX 16valve calipers
exactly. the only difference is that the pad carrier is slightly bigger to accomodate for the extra width of the vented disc. You coul just unbolt the normal yoke (its the weird 5 sided nut) and bolt new ones in, or swap the whole units if you can find known good ones!
You MAY have problems with standard rims and might have to get the 16v alloys to go with. I have put standard 165 rims on a 16v and there wasnt any obvious problems, but at the same time the car didnt run!
