My Xantia is doing the usual thing with the hyper-active regulator valve and I suspect that it is time to change the accumulator sphere. Reading the informative stuff already on this forum certainly points me in that direction. However, on my car the valve operation isn't so much a click as a dull metallic "clonk" at idle, becoming more of a metallic buzz as the revs rise - and it is a trifle annoying! Is this indicative of the sphere only or some other malady?
Also, this car has the Hydractive suspension - how do you tell when the additional spheres need replacing? And are these additional spheres used on all Xantias as part of the anti-sink system?
Xantia Accumulator and regulator diag.
The alternative to a flat accumulator is an internal leak (ie the leakage goes back to the reservior, rather than onto the pavement, typically due to a jammed valve), but the probability is strongly that the accumulator is flat.
In Australia, a number of enterprising individuals will regas spheres at very affordable prices in their backyard workshop, and we have a strong tradition of taking this option.
During 20 years of Citroening, I have only once had a membrane failure in a sphere (which means it is really dead).
If regassing the accumulator reveals that the membrane is intact and that it is indeed well below specification, then the time has come to regas all spheres.
- My Cars: C5 2.2 VTR + Nav 173
Mazda 6 2.2 Sports Nav Estate
Jaguar 3.8 MkII 1961
Ex 2007 C5 2.2 Estate
Ex 2003 C5 2.2 Estate
Ex Xantia 2.1 TD Exclusive
Ex BX 1.7 DTR
Ex BX 1.9 TRS - x 1
Thanks, guys. I'll get a replacement accumulator and then track down the other myriad little faults (not least the odd-feeling brakes - so different from the BX). And I've just had a thought that many people have possibly looked at this post thinking that there was a diagram of the accumulator and regulator! Could be a requirement? Diag. stood for diagnosis[:)]
Cheers
Cheers
