I noticed this morning that the central trim has vanished from one of the wheels. It must have fallen out last night on the way home.
It's for a 2003 VTR alloy wheel; I have searched in online auction sites (wheels but not the trim on its own) and on parts sites, but no luck yet. No local breaker to raid either.
Does anyone have any to sell - or know where I can get a suitable replacement? It would be good to hide the wheel nuts!
Thanks.
Jonathan
Mk1 C5 VTR alloy wheel trim required
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5722
Re: Mk1 C5 VTR alloy wheel trim required
There are several types of central plastic hub cap depending on the alloy you have fitted. If you send me a PM with your VIN I’ll let you know which one you need. Depending on the type they are relatively easy to obtain and not too pricey.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
I have a Mk1 VTR, and the wheels on her are Hungaro style;
http://www.ebay.co.uk/itm/ALLOY-WHEEL-C ... SwrfVZP-KM
https://www.ebay.co.uk/itm/New-Genuine- ... Swr7ZW69sY
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
There were three types on looking, depending on Alloy:
The Monza 16"
Again, this is cheaper from citroen direct - £8.69 Inc. VAT brand new (Part 542104). The monkeys below are charging double for a used one!
https://www.ebay.ie/itm/Citroen-C5-Allo ... OSwxOFaf0N~ The Imola 15"
Brand new from Citroen is £10.42 Inc. VAT (Part number 542113) - below is a new genuine one for a couple of £s less:
https://www.ebay.co.uk/itm/CITROEN-C2-C ... 2806329642 The Hungaro 16"
As for these, they are charging almost the same price for a second-hand used one as a new one from Citroen! Current brand new price for the Hungaro from Citroen is £22.72 inc. VAT. (part 542116)
The Monza 16"
- tontonjon
- My Cars: Deep Purple Mk2 Cactus manual and Emerald Blue Mk2 Cactus automatic
Used to own 1970 DSuper and 2003 C5 - x 7
Thank you! Yes, it's the Hungaro ones that I have. But the Monza ones are cheaper - do they fit in the same way, though?
More research...
More research...
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
They just snap in
- Donor 2023
- x 3007
While they do just snap in you must make sure they are lined up properly, otherwise they can get damaged. There are alignment tabs on the opposite side (up at the top of Marcs' picture, IIRC) that must go into the relevant place on the rim. On the attached picture this place is at the 2 o'clock position;
https://www.ebay.co.uk/itm/Genuine-Citr ... Swu4BV6Hti
The notch where you would place something to lever off the cover (lowest edge, Marcs' picture) lines up with the air valve on the rim.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- My Cars: Two C5's...
Lots of CXs...
A couple of Xantia...
A C2...
Lots of Prelude's...
And a Sunny! - x 66
- Contact:
Hell Razor5543 wrote: ↑25 Feb 2018, 18:41 While they do just snap in you must make sure they are lined up properly, otherwise they can get damaged.
Yep - the mrs C2 has suffered from that not being done correctly in the past so the centers are variously cracked etc. Very, Very annoying...
I will say that I have some sympathy with the previous culprits though, because the C2 has two of those locating recesses rather than one and it's not exactly easy to get them to pop in evenly all round at the same time - and unless you do, one or more of the the tabs don't go into the recesses and that's what causes it to flex and crack
Iain
1x '85 CX GTi Turbo s1 (metallic blue)
2x '85 CX GTi Turbo s2 t1 (metallic silver & grey)
'88 CX GTi Turbo s2 T2 (metallic light blue)
CX DTR T2 Safari (silver)
2x '96 Xantia Activa (Black & metallic green)
Iain
- tontonjon
Bought a new one online. £22 including postage. Amazingly, second had wheels including the centre can be got for about £10 more... Next time, perhaps!
