Afternoon all.
Did an oil and filter on my '09 2.0HDi auto this morning, spotted that the o/s outer CV boot is split open. Is the correct Citroen part number 3293E8, does anyone know? And do manual ones differ from auto ones? There's what seems like dozens of different ones listed!
Pete
C5 CV boot query
- milleplod
- My Cars: 2009 Citroen C5 2.0HDi Exclusive Tourer
(Previously, in order....Dyane, 2CV6 x 3, Visa 1.7D, GSA estate, GS Pallas, CX TurboII, Picasso...all fondly remembered!). - x 15
C5 CV boot query
Nocto Diuque Venamur.
- (Donor 2017)
- My Cars: Citroen C5 2.0 Hdi 2003
- x 39
Re: C5 CV boot query
I can't advise as to the part number for correct boot, but you might like to consider one of the universal stretch boots. I started using these a couple of years ago as they save a fair amount of work when replacing the boot. They can be do in situ just by removing the outer end of the driveshaft from the hub which, if nothing else, saves losing the gearbox oil.
I have used the below outfit who trade on ebay a number of times and their stretch boots seem good quality. I last changed a boot with one of theirs a couple of years ago (about 100K miles) and it is still going strong.
http://stores.ebay.co.uk/J-R-CV-JOINTS-DRIVESHAFTS
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
- van ordinaire
- (Donor 2017)
- Location: Live & work in London but weekend in Devon (or do I now live in Torbay & work in London?)
- My Cars: Citroens:-
'81 2CV Club (quietly sleeping in a parallel universe)
'05 (yes, really) C15
'97 Xantia Exclusive estate
others:-
'96 Jeep Cherokee Limited - the "donor"
'99 Jeep Cherokee Orvis - the green one
'97 Jeep Cherokee Limited - the red one
'99 Cadillac Seville STS
'96 Cadillac Eldorado ETC
& numerous what might be described as abandoned projects! - x 405
Personally, I couldn't be bothered, given that you can get a driveshaft for not much more than the cost of 2 boots BUT, I never realised you could fit them in situ: it looked like a bench/vice job to me!
Citroens:-
'81 2CV Club
'05 C15
others:-
Jeep XJ Cherokees x 3
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
I had to take mine to the bench with the stretchy boot. I only had the cone for the job, not the bellows. It is a faff...........horrible job.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- (Donor 2017)
- x 39
It can be done in situ even with a cone, although it is a bit tricky.
I'm sure that there was a recent thread on this forum concerning this topic. I modified my cone slightly by glueing a 15 cm length of cylindrical drain pipe onto the wide end if the cone (the drain pipe having roughly the same diameter as the wide end of the cone). This allows you to stretch the boot onto the drain pipe section of the cone away from the car, say on the ground, which is relatively easy. The stretch boot will quite happily sit on the drain pipe section without any need to hold it there. You can then offer the cone up to the driveshaft, so that the drainpipe section sits over the joint in the usual way, and slide the boot off.
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
- van ordinaire
- (Donor 2017)
others:-
Then there's the inner, because unless it was accidental damage to the outer, that has now got a limited life, so it makes no sense not to do them both at the same time.
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
