Xantia 1996 1.9TD 293K starting problem
Hi, just wondered if there's a common place to search for air leaks on these cars?
Normally fires first time.
She now if left over night or the 8 hours at work, she now unusually needs to be turned over many times 15-30 seconds before she eventually fires up.
Once running everything is fine.
Also after she runs, she starts fine if I turn her over again within a few hours.
I suspected an air leak in the fuel lines.
Confusingly tho, seeing as she was running fine when I stop the car, I'd have thought that the mechanical fuel pump would be acting as a reservoir and would be full of fuel for when she next starts, no? :/
I disconnected the feed banjo, pumped the priming bulb, fuel pumped out and only after a few spouts the inlet part of the pump was overflowing :/
hmmm?
I've ordered a load of transparent diesel filters and will put them inline in the feed and return lines as close to the pump as possible for diagnostics.
Cheers for any ideas/leads?
hmmm?
Citroen Xantia 1.9TD 1996 estate 100% veg 323k
Ford Transit Tourneo 2.5L Di 1999 165k
Yamaha R1 1999 26k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 1992 x 2
Mountain bike, skateboards, snowboards, surfboard, longboard and feet!
Yamaha R1 1999 26k
Re: Xantia 1996 1.9TD 293K starting problem
oh, I don't see any fuel puddles under the car in the mornings :/
Yamaha R1 1999 26k
Yamaha R1 1999 26k
Sounds like you're doing the right things. If you're running veg its worth looking at the fuel filter housing. They start to leak on the off side towards the bottom.
- Donor 2023
- My Cars: Xantia Activa - one day I`ll own her again! Also miss my `old` 405 GLx4
2005 C5 3 Litre V6 Exclusive in Mauritius Blue and my 1997 Xantia Exclusive V6 - x 23
I have a stunningly similar problem (bosch pump) - every day , have to manually squeeze the primer then either crank for ever or use easy start
already change glow plus and fitted inline 1 way valve and nothing ; next up is replace all leak off (they look old) fuel filter and rubber fuel lines - pipes off ebay were about £7 for 1 meter of each.
have liberally sprayed G101 and degunking the engine so I try to spot any leaks , but theres not a lot left for me to change - next up is fuel filter housing , pump seals and injectors
Simon
mines a Bosch pump
I tried priming and NOT priming with the blub, it doesn't seem to make a difference.
I wonder if an issue with the return might be a thing? I'll have to take the return banjo off and see what comes out while running, but as the car runs fine after it starts, seems rather unlikely.
I suppose getting a small transparent container then running hoses directly from this to the pump will show that the pump is 'pumping' correctly :/
Yamaha R1 1999 26k
Yamaha R1 1999 26k
- Donor 2023
my fuel line from filter to pump is transparent
" onclick="window.open(this.href);return false;
can you see the air pumping through?
Simon
good idea. Is it 8mm inside diameter for that pipe?
Yamaha R1 1999 26k
Yamaha R1 1999 26k
- Donor 2023
6.5mm
better video I think
Simon
I'll have to order some transparent 6.5
I see the bubbles in yours.
Did you have the same issues with starting, but then it running fine?
Yamaha R1 1999 26k
Yamaha R1 1999 26k
- Donor 2023
yes - took a minute of cranking to get it running for that second video - my son was starting it and and I was checking if the primer was solid (I t sort of was)
pm me the numner from your VIn and I can check on service citroen what the pipe number is for your car
Simon
pm'd
Yamaha R1 1999 26k
Yamaha R1 1999 26k
I don't understand tho.
The pump holds loads of fuel? Why can't it just fire on that from the beginning?
.... ohhhh, the pump, pumps all the fuel out, but gets little in return, yeah? :/
Yamaha R1 1999 26k
Yamaha R1 1999 26k
ta, is that for the fuel line?
What was causing your bubbles in the end out of interest?
Yamaha R1 1999 26k
Yamaha R1 1999 26k
- Donor 2023
yes - from filter housing to fuel pump , will get the rest of the numbers shortly.
as forbubbles - as mentioned in the PM - tbh I don't know , im sure air must be getting in , somewhere before the fuel filter (maybe even the filter housing itself?)
Simon
