Squeeling Noise
Squeeling Noise
Ive got a citroen zx 1.4i which has just hit 81000 miles. Recently while driving in straight line I can sometimes here a light sqeeling noise occassionally its not there all the time. I have also noticed it occassional when turning a sweeping left hand corner. Would I be correct in assuming that its one of the wheel bearing that have gone. But i have checked both front wheels for play in the 12 to 6 oclock position and 3 to 9 oclock position and i cannot detect any play.
hi
if it was a wheel bearing you would normaly here a whhrring noise not a squeling one.
i am assuming that the noise is coming from the wheels, have you checked the break pads inside and out as sometimes you will find that although they look fine on the outside the inside pad has worn down further.
edd
edd
