Hey guys im looking for a number of things here if you can help ?
Looking for the gearbox filler plug? cannot seem to see it anywhere
My cv Joint has gone twice this year, any ideas why?
My engine is screaming at 60mph, is this normal? i look after it very well and no problems i can see straight away.
Thanks in advance guys
Citroen Relay 1.9D year 2000 help!
Re: Citroen Relay 1.9D year 2000 help!
hi and welcome
it is usually black plastic with a small white plastic plug in the top, this white plastic plug i pull out before putting a 7mm socket on the screwed in black plug,
were are you located
the best place to full the gear box is throught the breather on top of the box, and on a Cit/Pug car just below the edge of the battery tray,Johnthejoiner wrote:
is it the CV gaitor/rubber boot, or the actual constant velocity joint failing,Johnthejoiner wrote: My cv Joint has gone twice this year, any ideas why?
Regards, malcolm.
Citronut, Thank you for the quick reply
The actually rubber boot keeps splitting and i keep getting knocking sounds from that wheel, untill i replace the boot then the knocking goes away.
The clutch has been altered all the way and i have to depress my clutch all the way otherwise it wont change gear,
And i am located in Merseyside Formby
so what type of boot are you fitting, stretchy, tailor fit or maybe a glue together type,Johnthejoiner wrote:Citronut, Thank you for the quick reply
is there any sharp bits very close the the gator, like drop link or swivel joint fixing bolts or the likes,
what do you mean by "The clutch has been altered "Johnthejoiner wrote: The clutch has been altered all the way and i have to depress my clutch all the way otherwise it wont change gear,
Regards, malcolm.
the gator was a stretchy,
The clutch has an adjuster on the arm where it meats the gearbox, it has been adjusted fully so assume the last owner has done this, and the clutch cable has stretched?
or maybe as the adjustment is at the end of its travel the clutch is at the end of its life????Johnthejoiner wrote:the gator was a stretchy,
Regards, malcolm.
