I've searched for this but can't find the answer. One of the batteries went on one of the fobs, replaced it and checked the voltage with a multimeter. But it still won't work.
I've only been able to find something on the internet, which says to put the ignition on, hold the lock key for 10 secs and then wait half a minute, but that but that doesn't work.
Any ideas to bring it to life again?
C3 key fob 08 model
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 231
Re: C3 key fob 08 model
First google search states:
To reprogram the key fobs to the Citroen C3 BSI (or ECU) follow this procedure:
Gather all the keys to the car and remove any loops or rings from the keys.
Sit in the drivers seat with all the keys and all the doors shut, radio off, no lights, everything OFF
Insert a key into the ignition
Turn ON the ignition
Press and hold the LOCK button on the key for TEN seconds
Turn off the ignition and remove the key
Insert the next key and repeat the procedure
WAIT 1 minute, do NOT switch anything on.
When the 1 minute is up, open the drivers door, exit the vehicle, close the door
Test the keys each lock and unlock the doors.
If the keyfob battery is flat you need a CR2016 its always worth having a spare to hand. The Lithium CR2016 last for years on the shelf (or in the drawer).
If you have the new C3, you will need a CR1620
As per my original post, that doesn't work.'
- qprdude
- My Cars: Renault 5 TS, Renault 14ts, Citroen C5 Mk1, Renault Clio sport, Renault Laguna Privilege. Citroen C5 X7 Exclusive. Citroen DS5 D/sport . And around 25+ other brands from Morris Oxford to S Type jag and most things between.
- x 10
Are the two procedures the same?
They read different to me.
Rick.
2013 Citroen DS 5 D/Sport
Neither is usually required, 08 model fobs either work or don't. Try disconnecting the battery on the car, suspect your fob has failed though.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Seems like it has failed. What's the cheapest way to sort the key, barring buying one from a dealer.
