Has anyone fitted a flywheel conversion to an RHR citroen c5 hdi
My flywheel has gone all of a sudden and ideally I would like to fit a solid one. However I've heard that the 6 speed gearbox has to have a dual mass and also the crank snapping because of no damping on the clutch
Anyway just wanted to know if these were true fact or speculation as I know people have done the conversion with the peugeot 307
Cheers josh
Solid flywheel citroen c5 138
- SaabC5
- My Cars: 09 C5 X7 2.0Hdi Exclusive
Re: Solid flywheel citroen c5 138
I put a new DMF in my 2.2Hdi recently, the old one lasted 110k before failing. I investigated a solid conversion but found it to be approx £60-70 more than the dual mass version. I've seen Mondeo 2.0 TDci's that have had a solid conversion come in with sheered driveshaft splines as a result of the un-damped power take up. I figured if the original was good for 110k then i'd go the dual mass route again.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
Mines just on 66k now I've had it from 58k. I've never had to replace a clutch apart from in my saab 9000 aero and that was my fault for running a stage 4 map lol
I have fitted a couple,(at owners request)
Always found them to be considerably less smooth, I will not fit them anymore, as the DMF kit is usually less money as said previously.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
I also hate the feel of them I don't care what anyone says they don't feel like a normal clutch
