Hey chaps!
i've managed to get the clutch done on the car, thank you all massively for all the advice, took 2 goes as first one clutch fork didn't locate but onlu noticed after everything was bolted back on and I went to put the clutch arm on!
Now, 2 questions!
1! How the Hell do you get the Spring back onto the end of the clutch arm pin? i've battled with it for half an hour and can't fathom it out! (Yes I know Should have taken a picture of it before hand! )
2! Do I Need to put the black pipe guide back on? (I havent yet due to Above!)
Think that was it!
Many thanks in advance!
Timmo.
xantia clutch done But! 2 Questions!
- Timmo
- My Cars: 58 partner teepee outdoor hdi.
58 C2 Code in black! Fun! - x 168
- Contact:
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
Re: xantia clutch done But! 2 Questions!
the spring i usually tap it into place, the curled/hooked end goes around the battery side of the arm neck, and the coiled bit goes over the end of the pin
Regards, malcolm.
- Timmo
- Contact:
Thanks for that, I have given up for today as light and patience went! tomorrows job!
'58 C2 Code
'58 C2 Code
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Black Tube????? Whats that?
Ive actually never put the spring back, couldnt work out what its actual purpose was!!
Never had an issue with the Pins either with the spring missing ...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
the black pipe/cable tray should really go back, even though its a pain in the BBBBB
Regards, malcolm.
- Timmo
- Contact:
I put the pipe rtray on first time and got it in remarkably easily! Had to take it out again as hadn't put the arm on! Haha! But will pop it on tomorrow after battling with the pin spring!
'58 C2 Code
'58 C2 Code
- Timmo
- Contact:
just a quicky chaps, struck me last night, Do you tap the spring onto the end of the pin Before putting the Pin back in the arm??
thought could save a lot of faffing that way??
TIA
Timmo.
TIA
Timmo.
'58 C2 Code
'58 C2 Code
i have done this both ways, but i think fitting it after the pin is home is a bit easierTimmo wrote:just a quicky chaps, struck me last night, Do you tap the spring onto the end of the pin Before putting the Pin back in the arm??
TIA
Timmo.
Regards, malcolm.
- Timmo
- Contact:
Thank you! Will finish coffe and a quick facebook stalk and off to finish it off
'58 C2 Code
'58 C2 Code
- Timmo
- Contact:
all back together and tested on the tesco shopping run!! Rediculously light pedal action and Low bight point, The complete opposit of the old one!
thank you all for the help and advice, it has been Very much appreciated!
Timmo.
Timmo.
'58 C2 Code
'58 C2 Code
GOOD WORK Timmo.!
Are you on FB Autshite or CCC pages???
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Timmo
- Contact:
Not that I know of! a few classic cars spotted types, but neither of those,
Just back from a night ride on the mtb before the pain kicks in from the car work!
'58 C2 Code
'58 C2 Code
