Hello,
On my series 2 Xantia - I have a fault with the window mechanism - I have fitted an new motor - but when the window goes up it is now at an angle. There is a guide for the window to travel up which is in the end of the door which has the speaker - but the other end of the door there appears to be no guide.
I have just purchased this car so don't know if it should have one or not - or is there something else I am missing?
Thanks in advance,
Terry
Xantia Window Guides Fault
- froggy
- Donor 2023
- My Cars: S2 Xantia Forte 185435.
Peugeot 306 Meridian, the boss. - x 2
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Re: Xantia Window Guides Fault
Im sure theres just the one LOWER guide in the door, BUT there should be a Glass Guide CLIP inside the Seal Area Rubber of the door.. On the Virtucally Straight Side. Theres a small hole in the glass that it clips into.. You might need to pull the Rubber window seal out of the framr a bit to see if its there, or not.
If this is how I under stand your problem correctly.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
