Hi all i wonder if one of you guys may be able to point me in the right direction.
My citroen relay van blower does not blow much air and im starting to suspect it my have a polen filter fitted, although it does not have air con. I have seen this before on other citroens without air con some still have a polen filter fitted.
My question is if i do have one where the hell is it fitted
many thanks
Relay polen filter?
Re: Relay polen filter?
if you send me the last 8 digits of your chassis/VIN No. i will check on service citroen for you
Regards, malcolm.
Thanks Malcolm i have sent you a pm
Let me know if you dont get my pm as it says its sent but then sits in my out box?
- qprdude
- My Cars: Renault 5 TS, Renault 14ts, Citroen C5 Mk1, Renault Clio sport, Renault Laguna Privilege. Citroen C5 X7 Exclusive. Citroen DS5 D/sport . And around 25+ other brands from Morris Oxford to S Type jag and most things between.
- x 10
That's the way it works Bick. I think it will disappear from your outbox when it is read.
Rick.
2013 Citroen DS 5 D/Sport
pm. received loud and clear,
they usually stay in your outbox till they are picked up by the recipient,
Regards, malcolm.
Thanks guys.
