Well ive had the C5 now for a little over a week and apart from a couple of niggles which ive sorted i am very pleased, i look forward to going out in it.
Any how went out this morn to a pals house and when i got back in it to go home the engine management light came on, so not bad really, i got a week out of it! The fault came up with Depolution fault, so i done a google on it and although ive done a fair bit of motorway driving i havent booted it, someone mentioned that you need to give it some wellie and go past 3000rpm which i did and bingo light went out, how cool is that, so im back to being a happy bunny, until tomorrow when ive got to have my shoulder operated on , that means no driving for 6 weeks. Still I can look out the window and look at it.
So if anyone has the same problem, that is worth a try......
Depolution System Fault C5
Micky
Citroen C5 2.0 HDI VTR 138 48k
Citroen Xsara 1.6SX Brilliant car, 9 years and 119000 Miles
2 Pug 306's
Peugeot 207 1.4 Sport
Citroen ZX 1.9D
If it aint broke.......
2 Pug 306's
Citroen ZX 1.9D
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1280
- Contact:
Re: Depolution System Fault C5
Don't worry, the light will be back on when you get back into it , it is a Citroen and is designed to surprise
Get better soon
Get better soon
Activa, the Moose Rider
3x C5x7 Steering racks and counting
Cheers bud, and im sure there will be a few surprises when i fire her up again
Micky
2 Pug 306's
Citroen ZX 1.9D
2 Pug 306's
Citroen ZX 1.9D
- Stickyfinger
AX, little Daffodil
- Contact:
Not your "Drinking" arm I hope
Yep!
Micky
2 Pug 306's
Citroen ZX 1.9D
2 Pug 306's
Citroen ZX 1.9D
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
Don't let the battery drain too low or you will have hours of fun resetting it...
Lexia ponce
Lexia ponce
My c5 has only 53k on clock the light only comes on if I boot it over 3000rpm, then goes off after an hour! So Im having the dpf removed and remapped £400!
Dave.
Dave.
- Stickyfinger
AX, little Daffodil
- Contact:
Not your "Drinking" arm I hope ........bugger!
There is always Lego !
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
Your fault sounds like my Xantia when I had a duff electrovalve controlling the turbo.
- My Cars: C5:Hatch & an Esatate. Real cruisemobiles.
It's usually this that brings on the light. A vacuum leak / duff electro valve causes overboost and this in turn brings up the anti-pollution message. Mine does it very occasionally, and that's had the dpf removed already. In fact I'm trying to source some replacement tubing (to help cure the vacuum leak) and was about to post a question............Stewart(oily) wrote:Your fault sounds like my Xantia when I had a duff electrovalve controlling the turbo.
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
