Hi all,
My 1993 Xant has an outer CV joint that is donald duck'd. Although it's the (expensive) long one (shaft) I'm inclined to fit a complete new shaft as it's the original and maybe the rest of the shaft isn't too far behind. Only trouble is I can only find shafts for sale for '95 onwards Xants GSF, Euro, CP4L and Mr Auto don't appear to stock them for my year (waited 15 min on hold for CP4L to be told they don't sell them).
Anyone had the same problem? Anyone have a solution (besides rebuilding the shaft)?? I am praying shafts are still available for the early type BE? gearbox ...
Many thanks,
Henry
Early Xantia Driveshafts (lack of)
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Re: Early Xantia Driveshafts (lack of)
BE3 gear box's were fitted right through the Xantia Series one eira. The difference I have found is the OUTER daimeter of the CV joint. IE: Theres a small CV joint size and a larger one.
Ive got used early shafts in good order, but never really had shaft issues with Xantia shafts. If the CV Boots are kept in good order and never split and loose the grease they can have a long life.
Also is yours an LX with NO abs or SX with ABS..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
if you send me the last 8 digits of your chassis/VON No. i will get you the correct OE part No. for your car
Regards, malcolm.
Cheers guys, my Xant is an LX (pas de ABS) and, with the car in the air (on lift), spinning the wheel produces a load of 'orrible clicking sounds and when driving sounds like spuds being shaken round in a plastic barrel.
The Chassis/VIN codes are the same apart from the chassis has a 0 on each end of it so: VIN last 8: 048A8711 and chassis: 48A87110. Hope this is good, Malcolm and pls excuse any 'duh'ness from this end.
PS Monroe or Febi/Bilstein spheres?
Best,
Henry
Best,
Henry
Neither... ifhs from citroen services (also know as aep) are the best....
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
here is part No. for new and exchange shaft for your specific car from citroen,
NFP mean no longer available
you can do a goooogly search with these No.'s to see if you can find some NOS shafts
96 164 213
NFP
DRIVE-SHAFT NEW
RIGHT
3273 P3
NFP
DRIVE-SHAFT EXCHANGE
RIGHT
pm.
sent with Characteristics list
96 164 213
NFP
DRIVE-SHAFT NEW
RIGHT
3273 P3
NFP
RIGHT
pm.
Regards, malcolm.
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
I have a pair of them in the garage that are surplus to my requirements since I went HDI
